• 29.11.2026, 04:56
Ryoba737
AQUAERO 6 XT - AQUABUS SETUP
Wednesday, November 4th 2015, 4:42pm
Hello everyone
This is what I have :
Aquaero 6 XT + 3 Poweradjusts 3 ultra + 3 D5 Aquacomputer pumps + 1 MPS flow meter USB
I need to get everything going here. Question is how to do it.
Question : Can I use a 4 pin Y cable to the connect the Aquaero 6 xt and 3 D5 pumps plus the flow metter ? So that would be 4 devices on 1 aquabus port of the Aquaero 6 XT.
Any smarter way to do it with the equipment that I have ?
Thanks for your replies =)
Thursday, November 5th 2015, 9:58am
All mentioned devices can be connected the same time via aquabus.
The poweradjusts have two aquabus ports so you can daisy chain them. The rest must be connected via y-adapters.
Poweradjust controllers and pumps only need a 3-pin aquabus connection while the mps flow sensor should be connected via a 4-pjn aquabus connection. It can also use a 3-pin connection but in this case USB must be connected too because otherwise the sensor will get no power.
Before you connect everything you have to assign different aquabus ID numbers for the devices. This can be done in the system tab of the aquasuite software when a device is connected via USB.
