• 18.11.2026, 10:43
yvelt
Friday, November 6th 2015, 2:19am
anyone knows why the Micro Drive G1/4 cooling block comes with a wrench and no screws? wondering how will it be able to screw on the HDD onto both sides of the plate?
Friday, November 6th 2015, 9:05am
You use the screws that came with your HDD or the case for example. The little wrench allows you to access the small gap for the screws when a second HHD will be installed.
yvelt
Friday, November 6th 2015, 1:51pm
HDD do not come with bolts anymore... and definitely not Hex bolts... hmmm not sure if can find a hex head bolt that is that flat to hook up the 2nd HDD ...
yvelt
Monday, November 9th 2015, 2:03am
do we need to use thermal pads/stickers for the HDD cooling plate?
Monday, November 9th 2015, 12:26pm
It would help to get better results. In the end it is like a block for CPUs or GPUs. Of course you want to minimize the roughness of the contact surface.
