• 13.11.2026, 09:22
Sp_i_ke
Aquastream XT or D5
Tuesday, December 15th 2015, 1:52pm
What are the differences between the two? Which one is better for my Situation (2 EK full MoBo blocks, 2 EK GPU blocks and 4 Hardwarelabs Radiators). Will use an Aquaero 6 to power everything.
Railgun
Tuesday, December 15th 2015, 2:14pm
The D5 allows for an integrated D5 pump in the base. The XT does not...you need an external pump. Which one is better depends on how you want to physically setup your stuff.
And how/why do you have two full board blocks?
This post has been edited 3 times, last edit by "Railgun" (Dec 15th 2015, 2:17pm)
Sp_i_ke
Tuesday, December 15th 2015, 2:28pm
I can't believe the only difference is the way they can be mounted. Which of the Pumps is more powerful? Which is more silent? ....
My server and desktop bunk together in the same Case (HAF stacker) and I will build one custom loop to cool both systems.
This post has been edited 1 times, last edit by "Sp_i_ke" (Dec 15th 2015, 3:57pm)
RE: Aquastream XT or D5
Tuesday, December 15th 2015, 9:42pm
The aquastream xt is an eheim pump at heart.
I believe the aquastream is quiter than the D5, but the D5 has better head pressure and volume... but neither has a huge advantage over the other.
The D5 is the more common choice for PC cooling loops.
Both have integrated reservoirs available.
This post has been edited 1 times, last edit by "InfoSeeker" (Dec 15th 2015, 9:43pm)
Railgun
Tuesday, December 15th 2015, 10:20pm
Holy crap I misread the OP. My bad. I read it as aqualis XT, not aquastream.
