• 07.10.2026, 05:28
zenworm
Fans running at 100% with powered fan hub
Thursday, December 31st 2015, 3:05am
Hey everyone! I'm having some issues with the Aquaero 6 and the Silverstone fan hub (http://www.amazon.com/gp/product/B00VNW556I/ref=ask_ql_qh_dp_hza).
If I don't plug in the fan hub's SATA power, the fans don't seem to be getting power no matter what I do with the Aquaero.
If I plug in the SATA power for the hub, the fans only run at 100% no matter what I do to the voltage, RPM, etc.
I'm using 3-pin fans, not PWM, if that matters.
I've tried searching the forums and can't find anything on this... any help would be appreciated!
Thanks in advance.
GTXJackBauer
Thursday, December 31st 2015, 3:11am
That hub is for PWM fans only so I'm not sure if its backwards compatible for 3-pin voltage control fans. I believe that might be your issue. You could find some other fan splitter hubs out there that should work in your case.
zenworm
Thursday, December 31st 2015, 4:38am
Hmm that may be, which would be a bummer. I'll try with some other splitters I have tomorrow.
It's weird because if they have SATA power, they send RPM signals to the Aquaero just fine, it's just that the Aquaero can't control them.
Railgun
Thursday, December 31st 2015, 10:56am
You answered your own question in the title. How do you control voltage controlled fans regardless if by voltage or RPM reading? How does that hub work?
Combine those two and that's your answer.
You want something like this, but you need to remove all but one of the RPM pins as you can't combine those signals. You won't get any sort of accurate reading.
It seems like you may not have read the product page.
This post has been edited 1 times, last edit by "Railgun" (Dec 31st 2015, 11:01am)
zenworm
Thursday, December 31st 2015, 3:03pm
Wow, yeah I just thought it worked the same as other PCB splitters. I didn't see anything like this on the Amazon page:
"Fan will not start unless SATA power cable is connected. Speed detection and PWM speed control are functional only when motherboard is connected."
I have some of the Mod My Toys PCBs that you mentioned, I was just trying to make my life easier with an integrated hub that looked nicer and came with it's own cable to connect to the Aquaero.
Oh well! Thanks for the help guys.
