• 12.11.2026, 23:15
barfly
Thursday, December 31st 2015, 10:08pm
i cant check as this pc doesn't have the a6 led but whats the purpose of a6/outputs/this device where it shows the 4 farbwerk channels and the a6 rgb?
That's exactly what mine looks like. I use Aquasuite 2015-9. I have a feeling the OP might have a older version.
barfly
Saturday, January 2nd 2016, 3:14am
ive ran into another odd issue,when manipulating the 4 led controllers in the aquasuite,such as color changes,setting triggers then it makes the same changes to all the led controllers.
any ideas?
nm,i deleted/re-added rgb's and it's corrected.
This post has been edited 1 times, last edit by "barfly" (Jan 2nd 2016, 5:29am)
GTXJackBauer
Saturday, January 2nd 2016, 7:57am
any ideas?
You must have put the same LED channels on each controller. Glad its working for you. Just takes time getting used to and learning the software/hardware.
