• 01.10.2026, 22:02
MusleHans
Aquaero 6 XT silver front replacement
Tuesday, January 5th 2016, 6:49pm
I want to replace the silver front of the aquaero 6 xt with the black one
can anybody tell me
Is it just the four srew's on the front? ore is the aquaero 6 xt glued as well?
Kind Regards
https://youtu.be/BNWOIj1_DUo
This post has been edited 1 times, last edit by "MusleHans" (Jan 5th 2016, 7:00pm)
GTXJackBauer
RE: Aquaero 6 XT silver front replacement
Tuesday, January 5th 2016, 10:12pm
can anybody tell me
Kind Regards
Both. I used a blow dryer and warmed up the panel before removing it before installing the black panel which is sold separately.
MusleHans
Tuesday, January 5th 2016, 10:34pm
Thanks for replay,
I have ordered the black front will arrive tomorrow
Thanks for the tip with the blow dryer .I am a bit concert removing the silver one,
must i glue the black one ?
GTXJackBauer
Tuesday, January 5th 2016, 11:02pm
Thanks for replay,
Just slowly pry off the faceplate once the you believe the adhesive is warm enough and than just line up and than install the black plate. Whatever glue is left should do the job. Its not perfect by any means but it should be good enough.
MusleHans
Wednesday, January 6th 2016, 4:41pm
Oke the black front was early delivered and with the blow dryer it was very simple to remove the silver one.
In the package there where no black srew's so i spay painted them to match the front.
Very happy with the Aquaero 6 XT, made a video on Youtube ( with silver front) with the flow sensor enz,
Kind Regards
