• 29.11.2026, 09:20
Enser
Farbwerk only outputting red
Wednesday, January 6th 2016, 11:44pm
As the subject says, my Farbwerk controller is the non-bt version. Have tried multiple outputs with different Aquacomputer RGB cables and multiple strips and no luck- only getting dim red every time. Using Aquasuite 2015 v9 and its showing up fine with full color wheel in Aquasuite.
Advice would be appreciated.
GTXJackBauer
RE: Farbwerk only outputting red
Thursday, January 7th 2016, 7:08am
Make sure the teeth from your LED cables are piercing in the right place of the LED strips and that the cable is connected correctly to the Farbwerk.
JasonMorris
Thursday, January 7th 2016, 2:47pm
I had this and it was down to the contacts not being aligned. Pull it and reseat it.
Enser
Friday, January 8th 2016, 9:51pm
Will take it out and debug, thanks for the advice!
