• 22.11.2026, 22:24
nightlust
Post your rig!
Monday, January 11th 2016, 4:44am
Share your rig here!
Nightlust
nightlust
Monday, January 11th 2016, 4:45am
Specifications:
Fractal Design Define R4
Fractal Design Newton Series 1000W PSU
3x Corsair 120PWM Performance Series Fans
2x 140PWM Fractal Ultra Silent Series Fans
Gigabyte GA-X99-UD5 WiFi
Intel Core i7 Haswell-E Extreme 5960X
32GB Corsair Dominator Platinum DDR4
EVGA Geforce Titan Z 12GB
Samsung 950 Pro M.2 512GB SSD
Sound Blaster ZxR w/ Daughter Board
NZXT IU01 USB Expansion Module
Pioneer BluRay Writer 16x
AquaComputer Airplex 240XT
AquaComputer Aquaero 6 XT
AquaComputer AquaStream Ultra XT
AquaComputer Aquainlet XT 100ml with nano-coating, and fill level sensor
AquaComputer High Flow Sensor
AquaComputer Cuplex Kyros XT
8x AquaComputer 10/8mm Coupling with O-gasket
6x AquaComputer 10/8mm Coupling with O-gasket elbow
AquaStream 10/8mm adapter
100mm AquaComputer 10/8 PVC-Tubing
100mm PrimoChill Yellow Anti-Kink Coil 3/8in
AquaComputer Blue Double Protect Ultra 1l
2x 4-pin Y-Adapter
8x 4-pin Extension Cable
4x 2-pin Extension Cable
4x 3-pin Extension Cable
Windows 10 Pro
This post has been edited 1 times, last edit by "nightlust" (Jan 11th 2016, 4:46am)
Nightlust
MusleHans
Tuesday, January 12th 2016, 8:41pm
https://youtu.be/BNWOIj1_DUo
custum watercoold Acrylic
Aquaero 6 Xt with flow meter
MSI Gaming M9 ACK
TiTan X
i7 6700K
This post has been edited 2 times, last edit by "MusleHans" (Jan 12th 2016, 8:43pm)
nightlust
Tuesday, January 12th 2016, 10:49pm
Very nice MusleHans!
Nightlust
nightlust
Tuesday, January 12th 2016, 11:02pm
Here is my Aquasuite layout:
Nightlust
MusleHans
Wednesday, January 13th 2016, 2:08pm
Thanks
your build is also awsome
how did you make? the custom 5.1 screen. witch sound cart?
water-noob
Wednesday, January 13th 2016, 3:33pm
Specs:
Anidées AI7-BW Cube
Intel Core I7 5820K @ 4.5GHz
4x4Gb Geil Evo Potenza DDR4 @ 3000MHz
MSI X99S SLI Plus
MSI Geforce GTX 980TI Gaming 6G @ 1500/7900
Samsung SSD950 Pro M.2 (System)
Samsung SSD850 Evo (Data/Games)
Corsair AX860 PSU
4x120mm Prolimatech Ultra Sleek Vortex Fan (Front)
Aquacomputer Farbwerk LED-Controller
Aquacomputer RGB-LED Strip 100cm
Aquacomputer RGB-LED Strip 25cm
Watercooling:
Aquacomputer Aquastream XT Ultra
Aquacomputer Aquaero 6 Pro
Aquacomputer Flowsensor "high flow"
Primochill Flow-Indicator Vortex Black POM/Deep Red
Nanoxia Coolforce 12/10 PETG-Tubing
Mayhems Ultra Clear 13/10 PVC-Tubing
12x EK HDC 12/10 Fitting RED
5x EK ACF 13/10 Fitting RED
4x EK ACF 13/10 Fitting Black
4x Bitspower 90° Adapter rotary Matt Black
3x Bitspower 45° Adapter rotary Matt Black
1x Bitspower Q-Rotary Extender
2x Bitspower Water Fill Set Matt Black
1x Bitspower Mini Valve Matt Black
MagiCool Copper Radiator 720 Hexa Xtreme
6x120mm Enermax T.B. Apollish UCTA12N-R Fan (Radiator)
EK Ekoolant Evo Clear Fluid
Mayhems Pastel Ice White
EK Reservoir X3 Lite
EK Supremacy Evo Red Edition
EK Mosfet X99 Gaming Nickel
EK RAM Monarch X4 Nickel with red Top x2
EK RAM Monarch Module Black x4
EK FC980 GTX Ti TF5 - Acetal+Nickel
EK FC980 GTX TF5 Backplate (R2.0) - Black
This post has been edited 1 times, last edit by "water-noob" (Jan 13th 2016, 3:36pm)
water-noob
Wednesday, January 13th 2016, 3:35pm
And this is my Aquasuite 8)
nightlust
Wednesday, January 13th 2016, 4:19pm
That is awesome water-noob!
I should of gone with the hard tubing, I do like it.
Maybe I will drain mine and do that!
This post has been edited 1 times, last edit by "nightlust" (Jan 13th 2016, 4:21pm)
Nightlust
nightlust
Wednesday, January 13th 2016, 4:20pm
Thanks
I have a post that goes over how to get that working: Right here!
It supports Realtek and Sound Blaster.
Let me know if you need any help with it!
Nightlust
barfly
Thursday, January 14th 2016, 1:24am
No pics yet as im still assembing and making panels but the specs are
corsair air 540 with modding
3770k @ 4.2 oc
16 gig crucial memory in a p8z77 pro m/b
h100i cooled
1tb samsung ssd for the os
6tb wd black for programs
6 ea. 2.5 hotswap bays
3 ea. 3.5 hotswap bays
aquaero xt with a aquaero 5 slaved and a farbwerk for lighting.
pics to follow.
Railgun
Friday, January 15th 2016, 5:59pm
Copied from another forum... I'll get pics up later tonight, not that there are many...
PC gear:
Mountain Mods Ascension with custom modded parts:
-Front Trinity panel for MORA fan spacing
-Rear Horizon panel for 140mm fan
-HDD Brackets for said 140mm hole (that I just checked and realized I was royally ripped off on...didn't even realize it at the time)
-Floor tray for pumps
Asus R5E
i7-5960x @4.4GHz
G.Skill Ripjaws F4-2400C15Q-32 (EK Monarch cooling blocks with short Corsair red top fins)
2x OG Titans with slightly modded NVIDIA SLI bridge @1.2/3.1 GHz
Corsair AX1500i
E-MU 1616M
Areca 1880i
512GB Samsung XP941 boot drive
1TB Samsung 850 EVO games drive
4X 2TB WD Black in RAID-5 for DAS
Water cooling gear (in order of flow):
Aquacomputer (AC) Aqualis XT 450
EK-XTOP dual DDC pump
AlphaCool UT60
Watercool MORA-3 360
Koolance CPU-380i
EX full cover Titan acetal+nickel (Koolance DUAL-VID connectors between)
EK-FB kit acetal+nickel
All PrimoChill 13/10mm red acrylic lines with Revolver diamond fittings.
Air cooling gear:
19x Nidec GT AP-53 fans for radiators, and general flow
4x 80mm NoiseBlocker BlackSilent Pro for top exhaust
1x 140mm NoiseBlocker BlackSilent Pro for DAS cooling
1x 40mm Fractal Design R3 for Areca cooling
Control:
2x AquaComputer Aquaero 6XT
2x AquaComputer Poweradjust 3 Ultras
1x AquaComputer Farbwerk
Lighting:
3x Phobya RGB LED strips (controlled by Farbwerk)
6x Vishay TLCR5800 red LEDs for reservoir (powered by mobo fan header)
Misc:
IcyBox external USB3 CD/DVD carrier
iStar USA 4-in-1 2.5" hot swap carrier
NZXT USB expansion
Various modded ModMyToys 3/4-pin expansion PCBs for fan aggregation/LED expansion
This post has been edited 4 times, last edit by "Railgun" (Jan 16th 2016, 9:41am)
water-noob
Friday, January 15th 2016, 6:22pm
Nice!! :thumbsup: :thumbsup:
The Tubing looks amazing
nightlust
Saturday, January 16th 2016, 1:15am
@Railgun
Wow man, that is incredible!
:rolleyes: :thumbup:
Nightlust
Kyle XY
Monday, January 25th 2016, 9:04pm
Impressive rigs ! :thumbup:
MusleHans
Monday, January 25th 2016, 10:23pm
[img]http://content.hwigroup.net/collection-images/usersystem/1920x1080/96479.jpg?d=1453756180[/img]
MusleHans
Monday, January 25th 2016, 10:24pm
inwin 909
nightlust
Tuesday, January 26th 2016, 10:50pm
Wow! Super clean MusleHans! Very nicely done! I really like those fittings.
inwin 909
Nightlust
MusleHans
Tuesday, January 26th 2016, 11:19pm
Thanks Nightlust,
really awesome system build here.
Kind regards
Kyle XY
Saturday, January 30th 2016, 7:33am
I am jealous of not having a configuration as clean as yours. For example, I would be very pleased of using rigid tubing, but I'm not sure that it will be as easy to maintain like with my present Tygon tubing.
Similar threads
