• 06.10.2026, 13:12
barfly
Aquaero lag
Tuesday, January 12th 2016, 3:08am
does anyone have any idea why the aquaero would lag between saving a profile and locking a profile?
at first i thought it was just my computer but with the same components in another build,that one also does it.
also when all the fans kick on the a6 screen will do like a reboot where the gauges disappear and then come back.ive tried raising the program process level but didn't help.
i just tried locking a profile and it took 8 seconds which is totally unacceptable.
any ideas?
ok,if i set the i/o priority from low to normal the lag is fully gone but a reboot sets it back
any ideas on a permanent fix?
This post has been edited 2 times, last edit by "barfly" (Jan 12th 2016, 3:46am)
RE: Aquaero lag
Tuesday, January 12th 2016, 4:24pm
any ideas?
I have seen the lag also, and I believe it is because aquasuite finishes the write/read function before continuing. I haven't seen 8 seconds, but a couple seconds, yes.
Are you using a third party data provider for Aqua Computer Service (HWiNFO/AIDA64)? I have noticed some screen flashing, particularly at startup, when HWiNFO is detecting and loading the various sensors.
barfly
Tuesday, January 12th 2016, 5:51pm
its roughly 8 seconds every time,cant be a taxed cpu as this is a 4960
changing i/o priority from below normal to normal fixes it so it must be a software issue.
barfly
Friday, January 15th 2016, 2:44am
bump for a solution.
Similar threads
