• 29.11.2026, 10:24
barfly
Aquaero sensor q
Sunday, January 17th 2016, 11:00pm
does the Aquaero have a sensor that tells what temp the Aquaero is running at?
RE: Aquaero sensor q
Monday, January 18th 2016, 2:16am
Yes, both the 5 & 6 show the 4 Fan Amplifier Temps.
barfly
Monday, January 18th 2016, 4:45am
arent those the temperatures of the fans as i have 8 fans with 8 fan amp temps,if not then how is it decided which one shows what area of temps?
This post has been edited 1 times, last edit by "barfly" (Jan 18th 2016, 4:47am)
GTXJackBauer
Monday, January 18th 2016, 6:18am
Those are temps of each channel. So channel 1, 2, 3 and 4. Temps will fluctuate or stay fairly similar in my case since I have a massive heatsink installed. Their max range is 80c so chances are, you'll have a long way ahead till you even get close to that point and iirc, AC told me that they have protection in place and so if they were to go above 80c, they would gradually lessen the load till the temps dropped to more of a appropriate range.
Monday, January 18th 2016, 11:34pm
Those four temperatures are the fan controller outputs/amplifiers of the aquaero itself (fan ports 1 to 4 on the back).
This post has been edited 1 times, last edit by "InfoSeeker" (Jan 18th 2016, 11:35pm)
Wednesday, January 20th 2016, 12:21pm
The voltage controllers of fan channel 1+2 and 3+4 share a temperature sensor (per pair). The temperature values of these pairs will be always identical.
There is a two-step security feature that will change the output power to 100% in the first step to lower the power dissipation and heat that it causes. If the temperature is still rising beyond a second limit the affected channels will be disabled to prevent damages.
The aquaero also has a temperature sensor for its CPU but we have disabled it in one of the last firmware updates because there were too many customers that thought it would show them the CPU temperature of their PC :wacko:
Wednesday, January 20th 2016, 12:56pm
Happy New Year Shoggy! Good to see you and Sebastian back :)
The temp sensor info is interesting, never really noticed that two were identical... guess I thought it more coincidental.
Might have been more informative if there were only two sensors listed as Amplifier sensor 1 & 2, and Amplifier sensor 3 & 4.
But good to know anyway, thank you.
barfly
Sunday, January 24th 2016, 1:18am
this brings up an interesting question,what version was this disabled?
in one of my builds which has an earlier software version from like 1 1/2 years ago shows the cpu in aida at high 50's as soon as i boot it and hangs in that range regardless of the pc load.
would aida64 show 2 cpu temps?
Sunday, January 24th 2016, 1:38am
I think (don't know exactly) the CPU temperature of the aquaero has been disabled with version 2015-3 from January last year.
If you use an older aquasuite/firmware combination you would see the CPU temperature as a normal value in the sensors tab of the aquasuite. No idea if AIDA64 was able to read it but if so it is hard to imagine that it would show it out of context next to your systems CPU temperature.
barfly
Sunday, January 24th 2016, 1:43am
i just went to the latest software and firmware and cpu temp is still in the 50's while the cores barely reach 30.guess i need new paste seating which will be a real pain
i was pulling this from aida as the a6 sensor doesn't show a cpu temp
edit
in sensors tab i only have 3 thermal sensors and 8 fan amplifiers showing as i have a slaved a5 also
appreciate the help
This post has been edited 2 times, last edit by "barfly" (Jan 24th 2016, 1:57am)
Similar threads
