• 30.09.2026, 00:42
OddsCrazyStuff
replace aquaero with usb?
Monday, January 18th 2016, 4:02pm
http://shop.aquacomputer.de/product_info…roducts_id=2901
Can I control those units the same way with usb as I would with an aquaero?
RE: replace aquaero with usb?
Monday, January 18th 2016, 11:51pm
Both the links you have are the same product, the D5 USB/aquabus pump, and yes, you can set the pump speed manually without an aquaero, but you cannot automatically adjust the pump speed with a controller, or set an alarm.
OddsCrazyStuff
RE: RE: replace aquaero with usb?
Tuesday, January 19th 2016, 11:02pm
Stupid copy past, meant this one as the other one: http://shop.aquacomputer.de/product_info…roducts_id=2897
Guess this one as well: http://shop.aquacomputer.de/product_info…roducts_id=3196
It might be easier with an aquaero, but I'm not sure I will have any front bays left.
Nor how much space in general, but if I find space, aquaero 5 LT works with everything?
RE: RE: RE: replace aquaero with usb?
Wednesday, January 20th 2016, 5:59am
Yes, the 5LT does all the 5 or 6 do.
If you wanted to use a 6, you don't need to mount it in a bay, you can mount it anywhere in the case.
OddsCrazyStuff
RE: RE: RE: RE: replace aquaero with usb?
Wednesday, January 20th 2016, 3:41pm
Is 6 not hard wired to use the LCD?
Also, if I dont have a front bay available, so will it most likely need to be mounted under or behind something.
Wednesday, January 20th 2016, 4:49pm
Every aquaero 5/6 uses a modular system:
main controller board -> display -> touch controller board
The main controller board alone is enough to make it work. There are no hard connections between these modules. Everything uses sockets with plugs.
RE: RE: RE: RE: RE: replace aquaero with usb?
Thursday, January 21st 2016, 4:44am
As mentioned by Shoggy, the LCD panel can be removed if desired and you would have a 5 LT or 6 LT, Though you can interact with the 5 or 5 through the front panel, it is a bit of a pain because the menu system is basically binary, so lots of clicking/tapping.
The much preferred manner to interact with any aquaero is through the free aquasuite program. The only requirement is that you connect the aquaero to the motherboard using a USB connection.
As to mounting, if you do not use a 5.25" bay slot, you may have to drill some holes elsewhere in the case to mount it.
This post has been edited 1 times, last edit by "InfoSeeker" (Jan 21st 2016, 4:45am)
