• 03.10.2026, 17:02
Focal
Need help setting up my Aquaero 5.
Tuesday, January 19th 2016, 1:10pm
Hello everyone,
I just finished my HTPC bulild. Tried to get my A5 up and running but no luck. The device itself seems to work fine. The pump, the fans, etc. I just can't do (adjust) anything in the Aquasuite 2014.
I also tried to reset the device with a jumper placed on the 8th temp sensor. It looks like the device is reset now, the fans and the pump are running at full blast.
However, the A5 demo page, reads the flow and the fan speeds just fine.
I had a problem with my A5 device when I bought one, sent it back and this one was sent as a replacement. I guess the replacement unit was not brand new, as it reads 125 days uptime.
I don't want to upgrade the firmware yet, I want to try the 2014 Aquasuite first.
I would like to set the pump (Laing 3.25 DDC) and the fans to 50%, monitor the temps and the flow.
Thank you!
And this is the 2015.
This post has been edited 3 times, last edit by "Focal" (Jan 19th 2016, 1:54pm)
Tuesday, January 19th 2016, 2:12pm
you have to use a actual aquasuite version, old versions are not supportet.
Focal
Tuesday, January 19th 2016, 2:27pm
Please explain. https://aquacomputer.de/software.html gives me 2 different versions.Tried them both. Whats the "actual aquasuite version" I have to get and where from?
Kind Regards
Tuesday, January 19th 2016, 3:15pm
you have to use the aquasuite 2015.
Focal
Tuesday, January 19th 2016, 3:22pm
So I have to upgrade the firmware as well to make it work correctly in the 2015?
Without the new firmware the readings are wrong, but my main concern is why can't I see the settings panel for adjustments?
Tuesday, January 19th 2016, 3:42pm
Update the device Firmware!
Focal
Tuesday, January 19th 2016, 4:14pm
Sorted. I was expecting it to work in the older version.
Thanks for your help.
