• 04.10.2026, 01:11
OddsCrazyStuff
ramplex RAM-cooler
Saturday, January 23rd 2016, 4:30pm
http://shop.aquacomputer.de/product_info…roducts_id=2786
"The cooler fits DDR-, DDR2- and DDR3-modules with or
without heat spreaders and is able to cool up to three modules at the
same time"
What type of heat spreader are we talking?
The small version like Crucial uses? http://www.crucial.com/usa/en/memory-ddr4-info
Or big once like HyperX Predator? http://www.hyperxgaming.com/us/memory/predator-ddr4
It might not make much sense to use them on heat spreaders, but its just to ensure the heat spreaders gets enough cooling, as the case might be a little stuffed.
Plus it help with the look, as most things in the system will be water cooled.
Also, can I use 2 of them side by side, on 4 ram sticks?
Saturday, January 23rd 2016, 8:05pm
The heatspreader should be flat and not cover the upper edge of the module. In your first link the last one seems to be OK.
The module from the second link will not work.
Two cooling blocks next to each other will usually work.
OddsCrazyStuff
Saturday, January 23rd 2016, 10:03pm
If that is the criteria, so do I guess these are my only choice:
OddsCrazyStuff
Saturday, January 23rd 2016, 10:07pm
Is the top plate (with text) removable?
Or can I replace the black part with plexi?
Saturday, January 23rd 2016, 10:24pm
Mhh, that viewing angle shows that the silver applications seem to stick out from the gray ground surface. Not really perfect because you will have to use a soft thermal pad to settle this.
The stainless steel plate is glued and can be only removed with some force. It is likely that you will damage (scratches etc.) the top when you try to remove it.
How do you want to replace the black top? You would need the same or at least a similar part again to make the block work :D
OddsCrazyStuff
Sunday, January 24th 2016, 2:22am
Was thinking that I could remove the text plate or replace the top cover to show liquid, as every other block in the system does.
But it seems that I cant find a ram that I can buy, that fits this block, when the heat sink is on.
So guess I will just skip it then. Its mainly for looks anyway.
