• 10.10.2026, 23:18
Aurosonic
How to send d5 usb pump rpm signal to cpu fan header ?
Thursday, January 28th 2016, 4:32pm
Hello.
Are there any way to send correct pump rpm value to cpu fan header of the motherboard? Using 3pin alarm header of the pump gives wrong rpm signal.
Here's screenshot: on top is the correct pump rpm and on the bot is rpm sent from alarm header of the pump to cpu fan header:
This post has been edited 1 times, last edit by "Aurosonic" (Jan 28th 2016, 4:42pm)
Thursday, January 28th 2016, 4:57pm
The alarm header only sends a static tacho signal as long as the electronic says the pump is OK. So it is just a "I am alive" signal and can not show the real speed.
Aurosonic
Thursday, January 28th 2016, 5:23pm
Yeah, i've figured it :) But are there any way to send real pump rpm to cpu fan header? I need this to make my Asus Front Base show realtime pump speed which it reads from cpu fan header. I know pump rpm signal goes through aquabus and usb cables which uses their own signal protocol.
Pilo
Monday, February 1st 2016, 5:11am
Does the normal/analog D5 or D5 PWM from Aqua Computer generate a real tacho signal?, because it's another analog PCB and not the digital mps circuit board, right? Is this analog RPM signal still accessible/present in the D5 Aquabus/USB pump mechanic and could it be made usable again by modding the pump?
This post has been edited 1 times, last edit by "Pilo" (Feb 1st 2016, 5:12am)
Jakusonfire
Wednesday, February 3rd 2016, 6:53am
The rpm wire is connected to an input on the mps board.
I guess you could split that wire and attach another fan connector but I have no idea if that would work.
I see that the new version of aquasuite finally integrates the USB pump into the front display pages so perhaps this is less necessary now.
This post has been edited 1 times, last edit by "Jakusonfire" (Feb 3rd 2016, 7:16am)
