• 08.10.2026, 22:07
k2mit
Daisy chaining multiple fans on Aquaero 6--PWM Question
Thursday, February 4th 2016, 1:34am
In a thread from a few years ago when the A6 was introduced, someone wrote:
"Daisy chaining multiple fans together on a Y-cable is possible, but be sure that only one RPM signal is reported back to the AE."
I need to do this but is not clear. If I want to put 4 fans on one A6 PWM header with a splitter do I get 1 4-pin PWM fan and 3 3-pin fans? Will that mane sure that only one RPM signal is reported back? I understand the concept
and am not sure if it is a change in fans (yeah, a bit cheaper) or a mod to the 3 connectors on the "y" cable.
Thank you very much. Brand new to AQ products and I have to say I am very impressed.
Oh, for those of us who are color blind, can these forums please use a different "human checker" The colored text on colored background is invisible for half of mine. Also, they are usually 4-6 characters. These are really long.
Why not a random number generator that does "4 - 2" = and you enter the text. I have seen that on the internet. it is colorblind friendly and quick to enter. I have no idea if it is fully bot proof.
Thank you, collectively, for your help. I have been reading for hours and can't figure the answer to this question.
--Jeffrey
Scarsdale, NY.
GTXJackBauer
RE: Daisy chaining multiple fans on Aquaero 6--PWM Question
Thursday, February 4th 2016, 2:44am
Alright. First you need to understand there are two options in fans.
3-pin = Voltage Controlled
4-pin = PWM (Pulse Width Modulation)
Its really simple. If you want to use 3-pin fans (voltage), you could use either 3-pin or 4-pin and if you want to use 4-pin fans (PWM), you can only use 4-pin Y-splitters and extensions.
You need to make sure which ever you use, you configure the AQ's channels as they are compatible with either or.
barfly
Thursday, February 4th 2016, 2:54am
when using a splitter cable just make sure only one fan has the rpm wire regardless be it two or more fans on the splitter.the fan header can only have one signal coming to it,so essentially all the fans run the same rpm assuming they have the same specs.
you can buy splitter cables that has only one rpm wire or just use a regular 4 pin wire and remove the extra 4 pin wire.
This post has been edited 1 times, last edit by "barfly" (Feb 4th 2016, 2:57am)
Jakusonfire
Thursday, February 4th 2016, 3:04am
3 pin fans still have an rpm wire and won't work properly on a pwm header
When they say only a single rpm signal they are talking about the wiring of the splitter cable. Four wires come out of the Aquaero but only a single fan will be connected to all of them. The other fans just skip the rpm wire connection but have the other 3.
Some splitter cables or boards come wired that way and some don't.
This post has been edited 2 times, last edit by "Jakusonfire" (Feb 4th 2016, 3:07am)
k2mit
Thursday, February 4th 2016, 3:06am
Ok, great. I didn't know there was a "only one 4 pin" Y cabe. Now, I will track that down.
So the 3 non-PWM / 1 PWM fan option doesn't work since PWM doesn't regulate RPM based on voltage whereas the 3-pin non-PWM fans do? Just want to make sure I got the electronics of this correct in my mind.
I appreciate the quick response.
barfly
Thursday, February 4th 2016, 3:57am
thx for reiterating my post virtually word for word :D
Jakusonfire
Thursday, February 4th 2016, 8:46am
Yep, that happens when you are both typing at the same time.
Although mine makes more sense. There was enough confusion already without saying things like make sure only one fas has an RPM wire ... They all still have RPM wires of course ;)
This post has been edited 1 times, last edit by "Jakusonfire" (Feb 4th 2016, 8:48am)
GTXJackBauer
Thursday, February 4th 2016, 10:56am
Alright Jakuson, no need to call out folks. The OP obviously didn't understand the difference between voltage and PWM until I explained it. I could have added the points you made about the importance of the signal wire but there's no need to come off as an ass.
k2mit
Thursday, February 4th 2016, 2:34pm
Sorry, no insult or bandwidth waste intended. I was just trying to use my words to make sure I understood what you kindly posted.
Thank you again.
barfly
Thursday, February 4th 2016, 5:47pm
actually no they dont all have rpm wires as having more than one will confuse the fan header and cause erratic readings,there can only be one fan -rpm- signal,im sure this is what was meant.
Jakusonfire
Sunday, February 7th 2016, 5:33am
What are you, you post police?
Nobody was being called out, it was actually a light hearted barb about posting the same info when they were clearly being written at the same time. Something that happens all the time in forums.
There's no need to come off as a douche that thinks the forum revolves around themselves and every post must relate to them.
Of curse they still have rpm wires. They aren't removed from the fan are they. They just aren't all connected back to the control header by the splitter harness or pcb.
That needed to be made clear seeing as the OP seemed confused by the difference between 3 and 4 pin fans.
Saying make sure only one fan has an rpm wire sounds very much like make sure the wire is missing from the others.
This post has been edited 6 times, last edit by "Jakusonfire" (Feb 8th 2016, 10:12pm)
Railgun
Sunday, February 7th 2016, 12:44pm
Man...you must type slow given the 10m time difference between posts. :)
This is all being made to be more difficult than it needs to be.
You need this.
http://www.performance-pcs.com/ek-cable-…n-pwm-10cm.html
Granted it's only for three fans...I can't find a cable that supports four. You'd need to double up on/daisy chain the cables.
Alternatively, get one of these...
http://www.amazon.co.uk/Phobya-8x-4-Pin-…M/dp/B00OD7MO6E
And you have room to grow.
This post has been edited 2 times, last edit by "Railgun" (Feb 7th 2016, 12:46pm)
Jakusonfire
Monday, February 8th 2016, 9:47pm
You need this.
Or Perhaps some of that was reading the preceding posts and I just didn't refresh to check for new posts before posting. Is this honestly a new concept? Being Ninja'd. Cause it happens like all the time.
Mostly people don't just don't feel the need to be so petulant as to say "I just said that" especially when that isn't the case.
The OP asked for an explanation of why, not what to buy.
This post has been edited 1 times, last edit by "Jakusonfire" (Feb 8th 2016, 10:10pm)
