• 19.11.2026, 06:56
belezeebub
Aquaero 6 Pro and Aquastream XT
Saturday, February 13th 2016, 4:32am
I have the Pump plugged into USB and POWER only it works but AquaSuite does not detect the pump I don't remember having to use the AquaBus interface on my last system but that was a few years ago
Questions
1. What does the USB interface on the Pump do if it doesn't talk to AquaSuite?
2. Do I need to plug in the AquaBus cable and still have the USB cable in place? or do I need one of the other?
RE: Aquaero 6 Pro and Aquastream XT
Saturday, February 13th 2016, 2:33pm
Questions
1. You can configure the pump, and manually control the pump speed with a USB connection. It should show in aquasuite under a MPS tab.
2. The USB and aquabus connections are complimentary, but neither is required.
You need the USB connection to configure the pump initially (only if more than 1 MPS device), but it can then be removed.
The aquabus connection opens communication with the aquaero, and is needed if you want to place the pump on a controller.
If the aquabus connection is NOT implemented, you will not see the pump in the pump tab of the aquaero.
I believe the aquastream XT acts similarly to a D5 USB./aquabus pump.
This post has been edited 2 times, last edit by "InfoSeeker" (Feb 13th 2016, 2:37pm)
RE: RE: Aquaero 6 Pro and Aquastream XT
Saturday, February 13th 2016, 3:32pm
This is not the case! The aquastream is not a MPS device! The aquastream has its own tab called "aquastream XT".
belezeebub
Saturday, February 13th 2016, 6:26pm
I do not see an Aquastream Tab and the pump is not listed under Pumps I am worried about plugging in the AquaBus cable because of the warning in the manual "if this is connected to an aquabus port the port must not be configured as a flow sensor otherwise the pump controller will be destroyed"
Ditze
Sunday, February 14th 2016, 9:35am
Are you sure the USB cable is plugged in correctly? That's the most common reason this happens and I experienced that myself :D
Alle Angaben ohne Gewähr :D
Sunday, February 14th 2016, 3:04pm
yes, if you do not see the device listed in a tab on the left side of aquasuite, there is a very high probability that your USB connection is fail.
The aquabus is very sensitive to noise on the USB connections. Also do not change a USB cable while either device is powered up.
belezeebub
Sunday, February 14th 2016, 7:09pm
Thanks for all your help it seems my Pump just came with a bad cable once I swapped it out everything is 5 by 5
