• 17.11.2026, 19:37
The Asgard
RGB LED stopped working after firmware update
Saturday, March 26th 2016, 8:55am
Hi there,
I have a Aquaero 5 XT and just upgraded to the new aquasuite 2016-3. After the upgrade it said I needed to upgrade the firmware. Everything worked fine apart from the RGB led appears to have stopped working. I have tried everything including a factory reset. Any ideas?
Other option is to downgrade the firmware and go back to the old aquasuite?
Many thanks
Saturday, March 26th 2016, 2:31pm
Might be helpful to provide a screenshot of the controller and outputs tab.
A downgrade is not possible.
The Asgard
Saturday, March 26th 2016, 8:26pm
Hi Shoggy,
Thanks for having a look at this.
If you need any more things give me a shout.
Many thanks
The Asgard has attached the following files:
  • Controller.JPG (211.99 kB - 191 times downloaded - Last download: Today, 6:21pm)
  • Outputs.JPG (152.43 kB - 161 times downloaded - Last download: Today, 6:21pm)
The Asgard
Saturday, March 26th 2016, 10:07pm
OK problem sorted.
It appears the black common had come away from the RGB LED. Must have been on the verge. Just weird it happened when it did.
Working fine now. Many thanks
