• 29.11.2026, 16:44
barfly
aq6 issue
Monday, April 4th 2016, 3:40am
i relocated my a5 and a6 in my case and once i connected everything i have 5 fans connected but the fan area shows 8 fans connected.
also i have one fan that i cant control even tho it spins during boot up.
resetting the software didnt help
if i reinstall the software,will my slaved a5 still work?
any ideas?
thx
This post has been edited 1 times, last edit by "barfly" (Apr 4th 2016, 3:41am)
Monday, April 4th 2016, 10:44pm
It is recommend to reset the slave device (jumpers on temperature sensor 5 to 8) and install the regular firmware. Afterwards flash it again with the slave firmware.
barfly
Monday, April 4th 2016, 11:33pm
??, jumpers 5 to what shoggy?
also does my issue sound like a reinstall is needed.?
Tuesday, April 5th 2016, 11:26am
When your aquaero 5 works as slave device (that is what I have understand from your post) it is no longer accessible through USB. To get access again you have to put the device into the recovery mode. This is done by placing four jumpers on the temperature sensor 5, 6, 7 and 8. You can also use four pieces of aluminum foil for example. When placed, start the device, wait for it to beep a few times, shut it down, remove the jumpers and start it again. Now you can flash the regular firmware and afterwards you can flash the slave firmware again.
barfly
Wednesday, April 6th 2016, 4:22am
thx shoggy for the help,all is good now
and i even figured how to boot up without any noisy fans running on boot up
nothing like a totally quiet system,especially when cooling doesn't need the fans running. 8)
i do have another concern
on the aquaero 5,is the fan pin assignment
pin1. for ground
pin 2 for 12 volt
pin 3 for speed
thx
This post has been edited 2 times, last edit by "barfly" (Apr 6th 2016, 5:00am)
Wednesday, April 6th 2016, 8:35am
Pin layout for every 3/4 pin fan header in the PC world is:
1: Ground
2: Voltage
3: RPM
4: PWM
