• 08.10.2026, 18:48
Meaker
New to aquacomputer, everything is a nice quality except the RGB LEDs.
Saturday, April 9th 2016, 6:19am
I needed to add fan/Pump control inside of my MSI GS30 gaming dock, an external x16 pci-e en lose for my notebook which I have added a custom water loop to cool my titan-x:
I have been borrowing both pwm control and LEDs from the gpu to do the above but I wanted to be able to control each fan and the pump by itself.
However I have to say I am disappointed in the quality of the LED strips I got, I ordered two 25CM strips and both have issues. The first has some of the coating peeling off at a couple of the joining points:
(by the blue connector) along with SOLDER on the pads of the other side meaning that can't go into a connector unless I wick it off and the other had one end cut to short to work in the connector:
So I can't use it to link strips together and the other side had holes punched into the pads:
They were also bent in their packaging and are official 25cm strips from aquatuning.co.uk. :thumbdown:
This post has been edited 7 times, last edit by "Meaker" (Apr 9th 2016, 6:34am)
GTXJackBauer
Saturday, April 9th 2016, 12:17pm
I have a problem with mine sticking up on top of the case or anywhere really as they are only a few months old. I want to say they've been installed since Jan/Feb. of this year. Wish they were the magnetic versions or at least had a stronger adhesive.
barfly
Saturday, April 9th 2016, 9:16pm
i just use 2 sided tape myself.
