• 10.10.2026, 13:09
AE5probigNGslave
Aqua Computer D5 pump motor with PWM input and speed signal - transfer rpm to flow
Saturday, July 2nd 2016, 1:52pm
Hello All,
Is there any way in aquasuite 2016-4 to transfer rpm of this pump to flow (approximately - virtually). I have Aquaero 5 pro, Aquaero 5 lt and this pump.
Thank you in advance for answer.
Sunday, July 3rd 2016, 5:27pm
I don't believe so. The flow rate is dependent on the loop as much as the pump.
You will have to add a flow sensor if you wish to know the flow rate in your loop.
AE5probigNGslave
Monday, July 4th 2016, 8:44pm
I thought so. Maybe it will react even Sebastian.
Thank you.
Tuesday, July 5th 2016, 7:09am
You can connect the rpm signgal to the flow connector and you have a flow signal.
But this makes absolutely no sense. The pump RPM has nothing to with the flow.
AE5probigNGslave
Friday, July 8th 2016, 8:46pm
Hello Sebastian,
Thank you for reply. Because I am a novice in the field of water cooling, I did not know that the resistance of the system greatly affects the final value of flow. I assumed that D5 is the macho pump.
