• 22.11.2026, 21:35
barfly
sensor issue
Tuesday, July 19th 2016, 12:24am
I have 6 4tb 2.5 drives in hotswap bays and using aida64 to show drive temps everything seems to function temp wise
but
when I remove these drives aquasuite still shows the drives as being monitored,meaning it shows temp functionality and changes
how is this?
This post has been edited 1 times, last edit by "barfly" (Jul 19th 2016, 12:36am)
GTXJackBauer
RE: sensor issue
Tuesday, July 19th 2016, 4:10am
but
how is this?
Have you tried restarting the PC after swapping them out?
barfly
Tuesday, July 19th 2016, 4:51am
shouldnt have to being its a real time monitoring app,to me that makes dependability useless , but for the record i dont trust hotswaps as data can be lost if when pulling their being read so yes powering down is always done.
Tuesday, July 19th 2016, 4:05pm
The aquasuite works with the last valid value that was provided by the monitoring program.
In the software sensor tab you could lower the timeout time and set a fallback temperature to trigger some specific action if required.
barfly
Tuesday, July 19th 2016, 6:06pm
so with the drives removed and after a over night coldboot,the temps begin@28 and rise to @35 or so and fluctuate as the fan is keeping temps in line and this is normal?
sounds as tho only a rear power pull will remove values
Wednesday, July 20th 2016, 2:20am
If the values continue to change after removing the drive, then you may not be monitoring what you think you are.
barfly
Wednesday, July 20th 2016, 2:44am
that crossed my mind but these 4 drives are the only samsung drives on here so that cant be the issue.
GTXJackBauer
Wednesday, July 20th 2016, 8:26am
That's what I started to think.
Wednesday, July 20th 2016, 11:23am
Whatever these sensors show: the aquasuite can only process what it receives from the third party tool so this is not a problem of the aquasuite but of AIDA64 if it still provides data.
