• 01.10.2026, 13:04
telefunken
Aquastream USB & Bus at the same time
Wednesday, August 10th 2016, 5:43pm
In the manual of the Aquastream under section 6.4 it is stated:
Quoted
USB and aquabus interface can be used at the same time, however not all control options of the aquastream XT are available using the aquabus interface.
How should this be read? Is it that not all control functions are available when both are connected OR is it that not all control functions are available over the bus even if USB is not connected?
Hufeisen
Wednesday, August 10th 2016, 6:32pm
this one.
if you want all control options, you must connect the aquastream on USB.
the aquabus Interface only provides limited control options, regardless if usb is connected or not.
telefunken
Wednesday, August 10th 2016, 10:53pm
Do you happen to know what functions aren't available? I'm planning a new build and I would like to keep the cable clutter to a minimum.
