• 02.10.2026, 04:24
telefunken
Access to the aquabus
Wednesday, August 10th 2016, 5:54pm
I would like to build my own custom hardware to interface with the aquabus, For instance I would like to create a fan hub which can monitor the speed of all the fans individually, so I can know whenever 1 fan fails. Also I would like to control the RGB led's of all the fans individually. Other then this I have a few other ideas which I need to flesh out and see how it goes during my new build.
I've been looking at the plugin SDK, it does provide some clues as to how the bus works but nothing to add your own hardware.
dawg
aquabus fan hub monitor
Saturday, September 3rd 2016, 5:47pm
me too
I thought maybe plugging in 2 same aquaeros would be possible to also read another 4 fans rpm as well
if you are prepared to work the sdk I can build the pcb & components if you wish
I thought the Aquaero had bus system already
Monday, September 5th 2016, 9:40am
The aquabus is a closed system that can not be extended with own devices.
