• 03.10.2026, 00:57
Beun
CoolCurrent 450 W Rev. 3 - EPS (24pins) connection
Saturday, November 13th 2004, 11:08am
Does the CoolCurrent 450 W Rev. 3 - Wassergekühltes Netzteil have a EPS (24pins) connection (new P4 systems)?
x-stars
Re: CoolCurrent 450 W Rev. 3 - EPS (24pins) connec
Saturday, November 13th 2004, 11:47am
The CC does have the normal 20-Pin-ATX-Connector and the 4-Pin-P4-Connector, if you really need an EPS-Connector (e.g. for Xeon-Systems) you should use an Adapter (you can buy it at pc-cooling.de or ask Stefak K. from AC-Berlin, he's always prepared for special interests ::)).
cya
x-stars
Edit: Maybe, I shoul add, that's not recommed to use ATX-NTs as EPS-NTs, becopuse in most cases you will need much power and the EPS-Standart was created to supply this power ;).
Beun
Saturday, November 13th 2004, 12:35pm
Thanx for the fast reply :)
I want to use it for a Asus P5AD2 Deluxe mobo (Intel 925X chipset). I prefer a watercooled PSU. So what to do...
NikoMo
NikoMod
Saturday, November 13th 2004, 12:45pm
hi,
we have a new board especialy for english (and english speaking) customers :)
Saturday, November 13th 2004, 1:01pm
This Asus-Board doesn't need the 24pin adapter. It can be used with 20/24 pin connectors. You can also buy the adapter (20>24) in our shop (but you dont need it).
Beun
Saturday, November 13th 2004, 3:30pm
Great to see an English section!
Thanx for all the help.
