• 14.11.2026, 12:02
Mayki
Aqua Computer RGB LED + FarbWerk
Friday, October 7th 2016, 11:13pm
Hello, can you advise me if I connect 2x Aqua Computer RGB LED on FARBWERK?
Thank you for answer.
GTXJackBauer
RE: Aqua Computer RGB LED + FarbWerk
Saturday, October 8th 2016, 3:49am
That single LED is designed for the Aquaero but I believe you could also use on the farbwerk but the farbwerk was designed to be used with RGB LED strips.
wa3pnt
Saturday, October 8th 2016, 4:36am
I do not think so.
The Farbwerk has an output of 12V Vcc, and then the RGB lines pull that low.
The RGB LED you are showing utilizes a Ground, and then a positive 3 to 4 volts on the GGB lines to illuminate the LED.
RodeoGeorge
Monday, October 10th 2016, 1:25pm
Does not work. The farbwerk uses a common anode while the aquaero and the RGB LED for it uses a common cathode.
