• 18.11.2026, 01:25
Darknesse
usb connection problem of Aquero 5 lt
Wednesday, October 19th 2016, 7:21pm
Hello,
I just bought a Aquero 5 LT, I made all the connection correctly, but can not have access to the Aquero on Aquasuite, it strikes me that the usb connection is not good. I tested with different usb cable that works very well for instance with the powerajust 3. But nothing works he will not make the connection with the USB cable.
Yet powerajust 3 and Farbwek works very well on Aquasuite
Is the product has a defect?
sry for English I speak french
Saturday, October 22nd 2016, 1:21am
Just to start somewhere, you have confirmed the USB connectors are oriented properly?
Darknesse
Tuesday, October 25th 2016, 5:10pm
Yes everything is properly connected.
Once information if it will help the red LED that confirms the connection flashes
Thursday, October 27th 2016, 3:50pm
The red LED on my unit is constant red while USB is plugged in.
Perhaps best if you contact support at support@aqua-computer.de.
They may be busy for the next couple of days, it looks like something new may be be released tomorrow, so be patient :)
