• 15.11.2026, 14:15
REDG
TwinPlex for DFI 855GME-MGF (Pentium M)
Sunday, November 14th 2004, 6:40pm
Hello,
AquaComputer Team, have you a project in progress for Pentium M.
A TwinPlex PRO for example with a specific fastener (6800 fastener modified).
M'en Bati Sièu Nissart
avalon.one
Re: TwinPlex PRO for Pentium M
Sunday, November 14th 2004, 7:57pm
For Use with the Aopen 855M Board u can use a standard AC cpu cooler. Retention Modul is just same as on other socket 478 boards :)
REDG
Monday, November 15th 2004, 5:48pm
But for use with the DFI 855GME-MGF :-[
See here http://www.x86-secret.com/articles/cm/dfi855/dfi855-4.htm
avalon.one
Monday, November 15th 2004, 5:53pm
mounting a twinplex is maybe possible but there is very little ,not to say no space at all ::)
size for twinplex is 40 * 40 mm :-/
REDG
Wednesday, November 17th 2004, 6:52pm
:P
NikoMo
NikoMod
Wednesday, November 17th 2004, 7:35pm
by now the only way is to use heat-compound-glue (i don't know the right word).
as i see on the picture the mountig-hole distance is 58mm.
this is similar to the twinplex for ati.
maybe you can use this?
crushcoder
Thursday, November 18th 2004, 5:23pm
Quoted from "NikoMo"
58mm?
if i don't have tomatoes on my eyes it's 41mm, since the twinplex is 40x40mm it won't fit.
but maybe it works if you turn the twinplex a little bit, so that the edges are between the holes.
in the shop under "ersatzteile" -> "Ersatz- und Austauschblenden" you can download TIFF-files with the "blenden" (what's an adaquate english word for these?), so you can lay these on the picture above to try if they fit in some way.
NikoMo
NikoMod
Thursday, November 18th 2004, 6:39pm
41² + 41² = 3362
sqr(3362) = 57,98 ~ 58
i was talking about the diagonal distance.
and 58mm fits to the twinplex for ati
crushcoder
Friday, November 19th 2004, 3:04pm
ok, then we are on the same path. ;)
REDG
Saturday, November 20th 2004, 2:20pm
Start again ;)
Twinplex is ideal for this motherboard, just a small rotation of 3.6° and it is good.
The question is : for more performance and to replace the old TwinPlex, AquaComputer plans to market a TwinPlex PRO.
Of course TwinPlex is largely sufficient :
but why not a TwinPlex PRO.
NikoMo
NikoMod
Saturday, November 20th 2004, 3:29pm
the problem is:
a pro version needs to have the in-connector in the center. and this moves the out connector to much outside, so that a twinplex-pro has to be bigger than a normal twinplex.
REDG
Saturday, November 20th 2004, 4:05pm
I know well ;)
There are solutions elsewhere, see HERE ::)
NikoMo
NikoMod
Saturday, November 20th 2004, 4:38pm
please don't show/link products from other stores
REDG
Re: TwinPlex for DFI 855GME-MGF (Pentium M)
Saturday, November 20th 2004, 7:23pm
For processor, TwinPlex with chipset fastener it's OK :D
But for i855 chipset, TwinPlex chipset CP4-Typ 1 or CP4-Typ 2 ?
I know, CP4-Typ 1 is for all Intel boards and CP4-Typ 2 for i850 boards but which is the physical difference ???
NikoMo
NikoMod
Saturday, November 20th 2004, 11:43pm
the position and distance of the "mounting-holes" is a little bit diffrerent.
Beun
Sunday, November 21st 2004, 8:55am
Quoted from "REDG"
I know well ;)
Isn't it possible to fit a cuplex pro on a
chipset. And if not are the plans at AC to make a pro version?
major23hh
Sunday, November 21st 2004, 12:57pm
the problem with the twinplex-pro is, that there is not enough place for mounting a connector in the center and the other at the side.
REDG
Sunday, November 21st 2004, 2:39pm
No CuPlex on chipset.
It's possible to create TwinPlex PRO but AC has surely another project in progress :'(
Also perhaps that TwinPlex PRO would not bring anything more than a standart TwinPlex compared to the overcost.
