• 16.11.2026, 10:07
Legolas84
Aquaero 6 and Aquabus port many problems ....
Friday, November 11th 2016, 11:15pm
Hello to all
I have a Aquaero. I connected to the Aquabus port the following devices:
2x d5 aquacomputer with aquabus interface
1x Farbwerk
1x Flow Sensor High Flow
Well, none of this works. The list of device connect to the aquabus port is empty.
Sometimes in this list appears Farbwerk... but I still can not control the LEDs in any way. The pumps and the flow sensor are never detected.
I use 2 Ycable Original Aquacomputer + 1 y cable Noctua.
During operation, the red LED on the Aquabus door on aquaero flashes.
In addition I have also installed 2 Aquacomputer temperature sensors. The first works well. The second detects negative temperatures. Why?
PS
The fan control is working well. I connected 12 Ek Vardar (three for controller) and can control them well.
I hope to resolve issues with the Aquabus port and the temperature sensor ...
Thanks!
Friday, November 11th 2016, 11:27pm
You must change the Aquabus-address on every connected Aquabusdevice via USB to a unique setting.
temperature sensors is probable broken, try swapping the connections:
This post has been edited 1 times, last edit by "EnigmaG" (Nov 11th 2016, 11:29pm)
Legolas84
Saturday, November 12th 2016, 10:49am
Thanks for you help!!!!!!
Now I see the d5 and ferbwerk, respectively with id 14, 15, 21.
But if I try to connect the flow meter, the Aquabus port locks, and is no longer detected any device.
If i connect the flow meter only, It is not detected.
Why? The model is this:
https://www.ybris-cooling.it/indicatori-…er-aquaero.html
Connect to aquabus with this:
https://www.ybris-cooling.it/accessori/1…uacomputer.html
PS
for the sensor I have yet to try your solution.
Thanks!
Morepower
Saturday, November 12th 2016, 10:56am
don´t connect the Flowmeter to Aquabus!Theres a "FLOW" connector on the AQ6 for that device,thats the cause for your problem.
Then it should work :thumbup:
This post has been edited 1 times, last edit by "Morepower" (Nov 12th 2016, 10:57am)
Saying that Java is nice because it works on all OS's is like
saying that anal sex is nice because it works on all genders.
Legolas84
Saturday, November 12th 2016, 11:16am
oh thanks.... now work well!!!
Legolas84
Saturday, November 12th 2016, 4:33pm
For temperature sensor, I tried to change the connector but remains stationary at -22,71"
Saturday, November 12th 2016, 5:17pm
Ok, contact the support.
