• 02.10.2026, 02:51
SverreMunthe
How do I code to show warnings and alarms
Thursday, November 24th 2016, 7:09pm
It used to be a premade page in Aquasuite for showing the alarm icon in the page, but I can't find it anymore. I have the relay, but need to find a way to program a data set (or whatever you call it) to show the warning level, together with all the fans, pumps, temps etc. Anyone know hoe to do it? I tried searching the Internet, but I probably don't use the correct search parameters.
Friday, November 25th 2016, 4:13pm
Just import the file aquaero_5_6.page again and copy the elements to your desired page. Creating that element again will requires some basic XAML knowledge and I also doubt that anyone has ever wrote a guide for that in the aquasuite.
SverreMunthe
Friday, November 25th 2016, 5:49pm
If I'm not mistaken it was available in the 2012 version. Is there a way to show which alarm(s)/warming(s) are active?
Friday, November 25th 2016, 6:21pm
As said, load (import) the template page for the aquaero. On the right side you have a bell icon which visualizes the current alarm level.
SverreMunthe
Saturday, November 26th 2016, 12:05am
That one only shows the icon. I want the one with alarm_0, alarm_1 and alarm_2. There was once a preconfigured control that used these 3 to show the alarm level.
Also, is there any way to show what warning/Alarm is actually in effect?
If both of these 2 were available it would add valuable information and the values necessary to program something like this must surely be available in Aquaero, otherwise the alarm's couldn't do anything.
If you don't have anything preconfigured can you tell me the names of the variables. This is one of the things I sorely miss with a manual, for Aquasuite. If I had, had a list of all the variables in Aquaero, I could have made the craziest controls, to show in Aquasuite.
SverreMunthe
Saturday, November 26th 2016, 2:00am
In this image you can see what I'm looking for. The green bell next to the temp icon on the right side. This was obviously available in 2012-5, as I mentioned.
http://s1129.photobucket.com/user/Namron…ttheLT.png.html
