• 24.10.2026, 07:46
lordimac
Fehler beim Dateiupload
Saturday, December 17th 2016, 5:33pm
Hallo aquacomputer,
euer Forum hat scheinbar ein Problem beim Upload von Dateien zu einem Beitrag.
Folgender Fehler erscheint:
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
Fatal error: PHP warning in file /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/data/message/attachment/AttachmentsEditor.class.php (141): sha1_file(): Filename cannot be empty
Information:
error message: PHP warning in file /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/data/message/attachment/AttachmentsEditor.class.php (141): sha1_file(): Filename cannot be empty
error code: 0
file: /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/system/WCF.class.php (255)
php version: 5.5.14
wcf version: 1.0.11 pl 3 (Horizon)
date: Sat, 17 Dec 2016 16:31:14 +0000
request: /index.php?form=ThreadAdd&boardID=1
referer: https://forum.aquacomputer.de/index.php?form=ThreadAdd&boardID=1
Stacktrace:
#0 [internal function]: WCF::handleError(2, 'sha1_file(): Fi...', '/srv/www/forum....', 141, Array)
#1 /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/data/message/attachment/AttachmentsEditor.class.php(141): sha1_file('')
#2 /srv/www/forum.aquacomputer.de/htdocs/lib/form/ThreadAddForm.class.php(107): AttachmentsEditor->handleRequest()
#3 /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/form/AbstractForm.class.php(88): ThreadAddForm->submit()
#4 /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/form/CaptchaForm.class.php(78): AbstractForm->readData()
#5 /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/form/MessageForm.class.php(181): CaptchaForm->readData()
#6 /srv/www/forum.aquacomputer.de/htdocs/lib/form/ThreadAddForm.class.php(288): MessageForm->readData()
#7 /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/page/AbstractPage.class.php(74): ThreadAddForm->readData()
#8 /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/form/MessageForm.class.php(221): AbstractPage->show()
#9 /srv/www/forum.aquacomputer.de/htdocs/lib/form/ThreadAddForm.class.php(349): MessageForm->show()
#10 /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/page/AbstractPage.class.php(36): ThreadAddForm->show()
#11 /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/util/RequestHandler.class.php(63): AbstractPage->__construct()
#12 /srv/www/forum.aquacomputer.de/htdocs/wcf/lib/util/RequestHandler.class.php(94): RequestHandler->__construct('ThreadAdd', Array, 'form')
#13 /srv/www/forum.aquacomputer.de/htdocs/index.php(8): RequestHandler::handle(Array)
#14 {main}
Grüße
Saturday, December 17th 2016, 7:09pm
Was hast du denn versucht hochzuladen?
Ich hab kein Problem mit der Funktion (eben ausprobiert).
Shoggy has attached the following file:
  • test.txt (3 Byte - 357 times downloaded - Last download: Oct 15th 2026, 5:34am)
lordimac
Saturday, December 17th 2016, 8:20pm
Ein normales JPG. Bekomme gerade auch weiterhin den Fehler wenn ich versuche hier ein Bild hoch zu laden.
Okay, es liegt wohl an der Größe des Bildes. Aber sollte dann nicht zumindest eine entsprechende Meldung kommen? Das Bild welches ich versuchte hochzuladen war ca. 3MB groß.
lordimac has attached the following files:
This post has been edited 4 times, last edit by "lordimac" (Dec 17th 2016, 8:50pm)
Zauberelefant
Monday, December 19th 2016, 4:13pm
"Maximale Dateigröße: 1,05 MB"
lordimac
Monday, December 19th 2016, 11:46pm
Oh da unten steht es, ganz schön klein. Danke für den Hinweis.
Das erklärt dennoch nicht den Fehler. Müsste doch simple Meldung kommen das die Datei zu groß ist, oder nicht? ;)
Zauberelefant
Wednesday, December 21st 2016, 1:14pm
Sollte schon, ja. Wäre wünschenswert :D
