• 03.10.2026, 19:41
apw63
Slave a A6 Pro to an A6 Pro?
Sunday, December 18th 2016, 4:51pm
I thought I read some where that this was now possible with new firmware updates? When I first got my A6 Pro I screwed up and got a little coolant on it. This resulted in the alarm function not working. The rest of the A6 works as intended. I sent the unit to AC and they replace the main board and sent back the new and old A6 units. I only have the one LCD screen.
Do I need 2 LCD screens to flash the other A6 or just take the LCD off the main A6, put on old A6 and flash? I would then return LCD to master A6. Are there any write ups on this for the A6?
Thank you for any help. :)
This post has been edited 1 times, last edit by "apw63" (Dec 26th 2016, 4:59pm)
Railgun
Monday, December 19th 2016, 8:36am
You can make any non-LT to an LT. the difference now is that the 6s can leverage PWM.
apw63
Monday, December 19th 2016, 1:35pm
Thank you, do I need to put an LCD screen on to the old A6 to flash, or is it all done in aquasuite?
Monday, December 19th 2016, 3:43pm
Only LT devices can be flashed with the slave firmware. So you have to remove the display to make it a LT variant.
apw63
Monday, December 19th 2016, 4:38pm
Sorry for my ignorance, but where do I get the slave firmware. I have figured out where to get the firmware. Thank you for the spoon feeding.
After flashing to slave I will gain 4 more PWM fan headers and 4 more temperature headers?
This post has been edited 1 times, last edit by "apw63" (Dec 19th 2016, 5:32pm)
Monday, December 19th 2016, 9:14pm
Yes
apw63
Monday, December 19th 2016, 11:13pm
Thank you, I will post how it goes
apw63
Tuesday, December 20th 2016, 5:59pm
The old A6 updated to latest firmware and then flashed to slave. The flashing worked as expected. I'm having an issue. When i connect the 4 pin aquabus cable from the main HIGH then to the slave HIGH and power up. The main A6 will not power up. What could be the possible issues?
Wednesday, December 21st 2016, 12:29pm
When the aquaero does not start in this combination, but does without the slave attached, then it is very likely that you have a short circuit there. Are you sure that you have used the aquabus port on both devices. I have seen it often enough that some customers use the flow port (no idea why).
apw63
Wednesday, December 21st 2016, 3:42pm
Thank you Shoggy. Short was what I was thinking. I did make sure and verified that both Aquaeros where connected to the HIGH bus. I have ordered aquacomputer brand 4 pin aquabus splitter and extension cables. I will let you know if this solves the short issue. I was using some cables I made.
apw63
Monday, December 26th 2016, 4:58pm
The 2 new aquacomputer aquabus cables solved the issue of a short that I was having. I now have 4 more PWM fan headers and 4 more temp sensors.
Similar threads
