• 06.10.2026, 09:29
XenoMorpH
Aquabus / RPM signal cable 3 pins problems
Tuesday, December 27th 2016, 11:22pm
I created my own Aquabus / RPM signal cable. Used 2 old 3 pin female cables and soldered them togheter and sleeved them. Made 2 of them, but they don't seem to work?
Does anyone has an idea why they are not working? I reconnected the standard (pretty long) cables and the devices work with my Aquaero.... But not with those 2 hand-made cables :(
RE: Aquabus / RPM signal cable 3 pins problems
Wednesday, December 28th 2016, 1:51pm
My initial thought is an open, or you crossed the wires... can't be much else.
Curious, what are you connecting to the RPM signal port?
XenoMorpH
Wednesday, December 28th 2016, 4:11pm
This is how I created them:
After soldering them I used some heatshrink to protect the solder-joint
Then I single sleeved the cables.
I have no idea why it's not working.....
They are not for the RPM port, fior the aquabus-port...
This post has been edited 1 times, last edit by "XenoMorpH" (Dec 28th 2016, 4:13pm)
GTXJackBauer
Wednesday, December 28th 2016, 10:36pm
What device were you using to connect them too since some devices need a 4-pin for power.
Wednesday, December 28th 2016, 11:11pm
Did you megger the cable with an ohm meter after sleeving to confirm continuity between the two plugs?
Thursday, December 29th 2016, 7:12am
your cables are reversed! Compare the pin numbers on each side of the cable.
XenoMorpH
Thursday, December 29th 2016, 11:42am
Using a PowerAdjust 2 Ultra and a Farbwerk. They work with the standard 3pin cables....
No I didn't, maybe that's what I could do.....
:S I think you are right :pinch:
Looking at this:
I now see that black and yellow are reversed. :whistling: Stupid me!
I'll try it out this evening Tnx!! :D
XenoMorpH
Thursday, December 29th 2016, 10:24pm
And it worked!! But now my Farbwerk is not connecting anymore. Not even with the original cables. :thumbdown: ... I Updated and Rebooted through USB, restarted the pc and reconntec it, but a no go ;(
XenoMorpH
Sunday, January 8th 2017, 2:17pm
Having a new problem...can not get any device work on the aquabus anymore. Not even with the standard cables.
I have 2 PowerAdjust 2 Ultra's, reset them to factory defaults, gave them a aquabus number (51 and 52).
Also the Farbwerk had a reset and gave it number (21).
The Aquaero had a factory reset, reconnected the devices one by one to the Aquaero, but they don't get detected. What's going on? :wacko:
XenoMorpH
Tuesday, January 10th 2017, 10:42pm
No one? ;(
Tuesday, January 10th 2017, 11:33pm
Your best bet may be to shoot tech support a message at support@aqua-computer.de
Similar threads
