• 31.10.2026, 16:22
galex
Aquasuite 2016 is no available for download
Sunday, January 1st 2017, 10:01pm
Aquasuite 2016 is not available for download at http://aquacomputer.de/software.html. With new license model, where some devices can be used only with 2016, you should add "final versions" of the software to support area.
For example, I'm an owner of D5 usb pump which is free licensed only till 2016 but I can't find the software.
This post has been edited 2 times, last edit by "galex" (Jan 1st 2017, 10:03pm)
Monday, January 2nd 2017, 2:30am
Download the aquasuite Software für x64/x86 Systeme, (2.506,9 kB) file you linked to and run it.
You may select which version of aquasuite you want to install from the drop down box.
galex
Friday, January 6th 2017, 2:22am
I'm sorry. I haven't seen that it is a drop down list. Thanks!
Reiser
Sunday, March 4th 2018, 8:21pm
This is not possible anymore. You have to pay atleast 10€ to get a aquasuite license now........................
Sunday, March 4th 2018, 8:29pm
I don't have a system I can test this on atm, but I believe the 2016 version will always be available.
If you have some gear that qualifies for the latest version, the 2016 option may not be shown.
Wednesday, March 7th 2018, 3:08pm
This statement is WRONG! Each device always has at least a license for aquasuite 2016 and this one can be downloaded for free through the setup tool (dropdown menu as as shown by InfoSeeker).
Devices that have a license for newer versions will keep them so for example for some customers aquasuite 2017 will be the version that they can download and install all the time without paying anything in addition.
Toux
Thursday, February 13th 2020, 1:32pm
The link is outdated. Does anybody know where I can get Aquasuite 2016 or other non-latest versions? The latest version from Support/downloads does not work on Windows 7, and it does not recognize Aquaero 5 Pro as a USB device.
This post has been edited 1 times, last edit by "Toux" (Feb 14th 2020, 1:35pm)
Thursday, February 13th 2020, 1:44pm
When your device is detected via USB the downloader give you a valid installer.
If your pc cannot find the device via usb, you cannot use the aquasuite. First your PC must find the device via USB.
Toux
Thursday, February 13th 2020, 2:05pm
My PC finds it, and W7 Device manager reports it as USBDeviceShare USB device stub; it also says that the device is working properly.
[I also attached a screenshot from AIDA64 indicating a product name for a USB device stub]
However, Aquasuite installer cannot detect it. Any ideas?
(NB: I also tried some earlier version of aquasuite_setup. it did not report any W7 compatibility issues, however it could not find a device too).
Another question is if I can get an installer explicitly, without usage of downloader?
Toux has attached the following file:
This post has been edited 1 times, last edit by "Toux" (Feb 13th 2020, 2:08pm)
Thursday, February 13th 2020, 2:10pm
When the setup dosent find the device, your USB connection or device is not working.
The aquaero 4 connects 2 devices, a hub and the device.
Check it in the device manager, not with aida.
Toux
Thursday, February 13th 2020, 2:28pm
Only one device is connected (USB stub). Windows device manager screenshot is attached. The USB connection is OK, other devices work well on it. I also tried to connect to another checked USB port, the same result. How can I check that there are no resouce assignment conflicts and What can I check to get sure that there is no hardware problem in the device? (probably, some self-diagnistics?)
