• 15.11.2026, 14:14
novax1
aquasuite 2016
Sunday, January 8th 2017, 9:22am
Hello everyone.
Happy New Year.
In the images that I show, and that indicates in red does not show a text, the temperature appears in its place.
regards
novax1 has attached the following images:
novax1
aquasuite 2016
Monday, January 9th 2017, 5:16pm
Automatic fan control does not work.
Our image
novax1 has attached the following image:
RE: aquasuite 2016
Monday, January 9th 2017, 11:43pm
Our image
I do not have an Aquastream XT, but let me toss out two thoughts.
Your "Target temperature" (23.0) is very close to your "External temperature sensor" (23.6).
Maybe not enough delta to start it.
Try lowering the target temperature to see if the that starts the fan.
Also, you can select the "Hold minimum power" option, and your fans should always run and not drop below the 35% level you have specified.
GTXJackBauer
Tuesday, January 10th 2017, 5:34am
As you can see, on the bottom left, you want to hit change settings so you're running AquaSuite in Admin and all your services are running.
novax1
Tuesday, January 10th 2017, 7:13am
thanks for your help.
Activated all services. It seems to work.
But only activated when it exceeds one degree above the temperature ??
Sorry for the English I have to translate.
novax1
RE: RE: aquasuite 2016
Tuesday, January 10th 2017, 7:15am
Our image
Thank you for your response and for your help.
GTXJackBauer
Tuesday, January 10th 2017, 10:23am
The service should be running at all times.
Tuesday, January 10th 2017, 4:39pm
It looks like he is using the External Temperature Sensor port on the aquastream.
I believe Windows Services is only required when taking sensor data from 3rd parties, like HWiNFO or AIDA64.
Though I guess it doesn't hurt to have Services running.
This post has been edited 1 times, last edit by "InfoSeeker" (Jan 10th 2017, 4:40pm)
