• 02.10.2026, 08:27
owikhan
new here
Thursday, January 12th 2017, 5:09am
hello
friend,s how i get free license of aquasuite 2017-1.3?
guide me regards
GTXJackBauer
Thursday, January 12th 2017, 5:25am
I'm going by the assumption that you have a Aquacomputer device otherwise you won't be able to use the software.
You go to the download page here and use the top link to install. Make sure to use the drop down to see what other versions you're licensed for.
owikhan
Thursday, January 12th 2017, 5:32am
licensed for 2016-5.3
i want new one and also first time buy this device.I want to learn how i control i7 4790k max ghz and lowest temps
Thursday, January 12th 2017, 5:02pm
You have the free version of aquasuite (2016-5.3).
To get version 2017-1.3 you need to own a recently purchased aquacomputer electronic device, or pay a license fee.
Details here
owikhan
Sunday, January 15th 2017, 12:10pm
how i get maximum speed with use of aquasuite 2016-5.3?
to get more less temps for i7 4790K @4.9GHZ
Sunday, January 15th 2017, 12:30pm
Aquasuite has nothing to do with getting speed out off a CPU, the Aquasuite controls Aqua-Computer-Devices only.
If you want help, you have to tell use what Devices you have and what your goals are.
GTXJackBauer
Sunday, January 15th 2017, 12:35pm
Get a better cooler or lower the clocks as those clocks shouldn't be used 24/7 since you're most likely degrading your chips longevity. I would only clock that high for benchmarks and bring it down to a normal 4.4-4.5-4.6, which ever gives you the best temps and lower voltage overall.
What Aquacomputer devices are you using Aquasuite with?
owikhan
Sunday, January 15th 2017, 1:36pm
how i set maximum pump speed?
Sunday, January 15th 2017, 3:10pm
apw63
Sunday, January 15th 2017, 5:12pm
Start here this should answer a lot of your questions I did not make this and its for the Aquaero 5. Most if not all of this still applies to newer aquacompurter components.
My Aquaero 5 Review & Guide & BASIC HOW TO SET UP GUIDE
Monday, January 16th 2017, 12:23am
If you have the hardware in place and are asking the best way to set up the aquaero, here is one option:
  • set your pump(s) to get the flow rate you are comfortable with (200 to 300 L/H)
  • place a Temperature Sensor (like THIS or THIS) in the water loop to read the water temperature
  • have an Ambient Air Temperature Sensor (like THIS) outside the computer case to read the room (ambient) temperature
  • connect your Radiator Fans to the Fan Ports on the aquaero
  • set up a Virtual Temperature Sensor in aquasuite for the difference between the Water Temperature and Ambient Air Temperature
  • set up a Fan Controller Curve that increases Radiator Fan Speed as the Virtual Temperature (Water-Air) increases
