• 17.11.2026, 09:16
CroyAlore
Aquaero 5 and 6 Display Question
Tuesday, January 24th 2017, 10:28am
Hello.
I was looking into getting a Aquaero 6 LT. I was wondering if the Aqauero 5 PRO display is compatible the Aquaero 6 LT. And is the Aquaero 5 and 6 displays identical?
Thank you.
willwrk4internet
Monday, February 13th 2017, 11:29pm
I would like to bump this question, because I too am very interested in this.
I noticed in the manual it says that the LT models do not have infrared capabilities, but I don't really care about that.
Otherwise, is it possible to install an Aquaero LT into the LCD display of an XT or PRO model?
Railgun
Tuesday, February 14th 2017, 11:12am
Given you can retrofit an xt or pro to an LT, yes. It's only firmware that's the real difference. The HW is the same.
Whether a 5 screen will work with a 6 base unit...I've not seen a 5 up close so I can't comment. I have two 6s, one of which I've flipped back and forth to an LT.
This post has been edited 1 times, last edit by "Railgun" (Feb 14th 2017, 11:13am)
willwrk4internet
Sunday, February 19th 2017, 12:29am
Actually I think the issue is not in going from a XT to an LT, the question is whether you can put an LT into an XT/Pro screen.
The manual specifically says on p.12 that the LT models do not have infrared receivers. So unless that receiver is part of the LCD screen, I assume that functionality will be lost. Is anything else lost by doing that?
Similar threads
