• 10.10.2026, 15:26
shonuff
How do you change this?
Sunday, November 21st 2004, 6:56pm
Hello...
I ordered the AquagraFX 6800 and I would like to change the blue logo to green . Can I do that with a green LED? If not how would you suggest I do it?
Here is a picuture of what I would like to change to green.
[img] http://img.photobucket.com/albums/v392/shonuff66/aquagrafx6800_highlight.jpg [/img]
The theme of my case is green as seen below.
Katzenfreund
Re: How do you change this?
Sunday, November 21st 2004, 10:46pm
Well, it could be possebill but are you sure, that there will be no leck later?
juergen_schelhorn
Monday, November 22nd 2004, 8:32am
Quoted from "Katzenfreund"
That`s the reason for the question I think! ;) ;D
I don`t know, how to get the Plexi of! Maybe it`s glued (heißt doch so oder ;D)
Ripper
Stefan_K.
Monday, November 22nd 2004, 1:08pm
mine is in green. Please note that everything you do is on your own risk.
1. Take of the steel plate.
2. pull out the blue LED
3. put in the green LED
4. Mount the steel plate
That´s it !
It could be helpful to have some glycerine for the mounting. Use ist on the fittings for all the curves inside.
Quoted from "Jack"
The plexi is fixed with a small screw. No glue anyway.
Cheers
Stefan
shonuff
Monday, November 22nd 2004, 4:21pm
Thank you very much for your reply. That is the answer I needed.
Do you have any pictures of the AquagraFX with the steel plate removed?
Thanks again!
