• 08.10.2026, 22:04
DirtyBear
Daul 400 MPS flow Sensors
Sunday, February 5th 2017, 11:20pm
Is it possible to have 2 400 MPS flow and 2 Aqualls connect to one 6XT ? ?(
Anyone can help ?
This post has been edited 1 times, last edit by "DirtyBear" (Feb 6th 2017, 12:05am)
Tuesday, February 7th 2017, 2:58am
Yes.
The aquabus can address up to four MPS devices (12. 13. 14, 15).
The two MPS 400 flow sensors will each take one address.
Assuming you are referring to the aqualis with built in level sensor, then two of those would take up the balance of the available addresses.
MPS addresses can be assigned in aquasuite under the system tab for each device.
DirtyBear
Wednesday, February 8th 2017, 6:16pm
That means I can only 2 400 flow sensors and 2 aqualis and I can not connect the D5 usb pumps
This post has been edited 1 times, last edit by "DirtyBear" (Feb 8th 2017, 6:17pm)
Thursday, February 9th 2017, 5:44am
The aquabus has four (4) MPS device addresses available.
If both aqualis reservoirs have the built-in level sensors, then the additional two MPS 400 flow sensors would max out the aquabus' MPS addresses.
You will still be able to manually control the two D5 USB/aquabus pumps with the USB connection.
Pumps are generally considered set & forget anyway, so that would be a viable option.
If you want the D5 USB/aquabus pumps to be integrated with the aquaero, then either the flow sensors or the level sensors would have to go USB connection only.
It appears you have six MPS devices, so you will have to select which four you want to integrate with the aquaero.
DirtyBear
Thursday, February 9th 2017, 11:26am
Many Thx :thumbsup:
Similar threads
