• 23.11.2026, 06:23
barfly
slave install
Saturday, February 18th 2017, 8:15pm
i have a a6 pro with an a5 slaved,a5 being its voltage controlled wants to run a bit hot so im gonna get another a6 to slave instead of the a5
i know i need to unslave the a5 before removal in the event it may be used later on but i cant recall the exact steps for slaving
can someone enlighten me on the procedure?
also being im getting a new a6,it will come with latest software,is it really beneficial to use this version and should i install this version on my current master a6 before i slave?
thx in advance guys
barfly
Sunday, March 5th 2017, 6:02am
once again,thx for the help
Sunday, March 12th 2017, 6:06am
For "unslave":
Quoted
1. Shut down the PC and disconnect all cables from the aquaero except
the power supply.
2. Place jumpers on temperature sensor input 5, 6, 7 and 8.
3. Supply power to the aquaero and wait for approximately 60 seconds.
The device display will show information on the deletion process.
4. Shut down the power supply and remove the jumpers from the temperature
sensor inputs.
5. Connect the USB port of the aquaero to the PC's motherboard and turn
the power supply on.
6. Start the aquasuite software and perform a firmware update.
7. Shut down the PC, reconnect all cables, then reboot the PC.
(Manuel, p. 51)
To flash the slave firmware you need to connect the aquaero to the PC with USB, open the aquasuite, goto aquaero > system > expansion device firmware
