• 12.11.2026, 18:30
Yata
First time user, problem with Aquastream XT
Saturday, February 25th 2017, 4:27am
Hey guys. I recently purchased the aquastream XT and acompanying aquainlet 150. I removed the grey plastic cover and took off the mounting bracket and attached the aquainlet to the side to see what it would be like fully assembled.
Now I have a problem, I literally can't take it apart.It doesn't appear to be able to be squeezed in to remove the two clips locking it in place.
I was wondering if it would be possible to push some sort of object in the clip holes and if that would help but I would need some advice on best how to do this without damaging anything.
I hope I've not screwed myself here as I really only need to get the mounting bracket on before I'm good to install it.
Thanks
Undesirable
Monday, February 27th 2017, 3:55pm
Looks like it needs to be squeezed on the AquaInlet side, but it seems to be rigid acetal.
If you can't squeeze it then you need to poke the clips with something fairly soft so it won't damage them.
I am aware of all the double entendres above.
This post has been edited 1 times, last edit by "Undesirable" (Feb 27th 2017, 3:56pm)
