• 14.11.2026, 23:32
Bytales
Replacing the Pump from a Radiator/Pump Combo
Thursday, March 9th 2017, 12:16pm
I believe the Pump from my "AMS 420 mm,Copper Radiator, D5 Pumpe mit USB/aquabus (Article Number 33064)" is somehow broken as it makes a very loud vibrating noise.
I'm going to take the Radiator out and take a better look at it, the question is, can this be replaced with a new pump (Article 41093) ? Or is the pump somehow soldered to the Radiator ?
Friday, March 10th 2017, 5:28pm
You will see when you take the radiator apart, but I believe you will be able to remove the pump's retaining ring and easily remove it.
Bytales
Monday, March 13th 2017, 9:55am
Yup, it can be taken away by unscrewing the 4 Screws that hold it together.
I took the Pump away from my second Radiator to compare it to this one that vibrates. The working pump spins a whole cycle without resistance, but the broken pump spins with resistance at some Point, which cause it to vibrate when connected to power.
I can't tell if i can fix it, so i ordered a new pump.
