• 06.10.2026, 12:54
pillager
Aquabus Splitter & ID Questions
Saturday, March 11th 2017, 1:57am
Hello all, I have a few questions about the Aquaero 6 Pro setup I'm putting together. While I was still in the planning phases I posted my setup here: Aquaero/Aquabus Dual Loop Questions
Anyways, now that I have all the parts in front of me and am progressing into the build, I need some advice. I ended up using a Splitty 9 for my Aquabus bus, and Shoggy previously explained about Aquabus ID's and the need to set them. I will be running 2 D5 pumps and 2 flowmeters via the Splitty, but I am avoiding USB to save on unsightly wires in the finished product. While it won't be a problem to boot up using USB and unplug later on with the flowmeters, the pumps are a different monster. They are both mounted in a reservoir setup (Monsoon MMRS) to the back of a radiator, and there is only a few mm of clearance between the bottom of the case and the pump cover. Basically, once they're installed and filled, it would require a complete system tear down to add or remove a cable.
I'll be leak testing just the reservoirs/pumps on my test bench soon, and was hoping I could set the Aquabus ID during that phase. I am planning on using an adapter to connect the pumps USB headers to a USB-A on my laptop, installing Aquasuite on said laptop, and setting the Aquabus ID numbers there. My question is, one, is there any reason why this wouldn't work, and two, is the Aquabus ID stored somewhere in memory on the pump itself?
Thanks!
Saturday, March 11th 2017, 5:57am
  • q one: is there any reason why this wouldn't work?
    a one: no, there is no reason why that would't work... or yes, you can set the aquabus ID using your laptop.
  • q two: is the Aquabus ID stored somewhere in memory on the pump itself?
    a two: yes, the pump retains the assigned address in flash memory.
This post has been edited 1 times, last edit by "InfoSeeker" (Mar 11th 2017, 5:59am)
Similar threads
