• 13.11.2026, 15:38
HunterVee
Dr. Delid with Haswell
Saturday, April 1st 2017, 5:09pm
Heya Aquacomputer,
Got a simple question, will Dr. Delid which is advertised to delid Skylake and Kabylake, be good for delidding a Haswell processor as well? has anyone tried it before on a 4790k?
Thanks in advance for feedback :D
Sunday, April 2nd 2017, 7:43am
you have to remove the indexing plastic pins at the Delrin part with a sharp knife. Then it will work.
HunterVee
Sunday, April 2nd 2017, 12:49pm
Hi Stephan,
Thanks for the answer, is there some picture that shows said plastic pins? you mean on the Dr. Delid itself no?
Friday, April 7th 2017, 3:25pm
Yes. At the pocket in the Delrin part that covers the CPU are two pins that you have to remove.
Friday, April 7th 2017, 5:03pm
