• 07.10.2026, 01:18
xsplice
Losing settings after every restart Aquaero 6 XT
Saturday, April 8th 2017, 3:57am
Hi All!
Figured this is the best place to ask since Google has failed me.
I keep resetting to default settings after every restart. I set the fan speeds and the controllers and they run great. I save them and close out of aquasuite. They keep working great.
Once I restart, the Aquaero goes back to factory settings and blasts my pumps and fans. (20 fans and 2 pumps at full blast is not fun).
Things I've tried:1. Reflashing firmware.2. Resetting to factory and doing all the setting anew.3. Doing the settings on the Aquaero only.4. Disconnecting the USB cable after the setting are applied.5. Different power supply.
No dice at all. And the worst thing is that I'm not finding much on Google, which is baffling.But, probably means that I've messed something up.
Any help would be greatly appreciated. Booting every day and having to to apply setting anew is getting old fast.And for a $200 USD unit it really stings.
Thank you!
Fieldrider
Saturday, April 8th 2017, 6:04am
Did you safe the Settings afterwards by klicking on the Floppydisk Symbol on the Aquaero Tab?
xsplice
Sunday, April 9th 2017, 4:47am
Yup, every time. No change.
I'm beginning to feel that I have a defective unit.
Gonna contact support.
Dundys
Sunday, April 9th 2017, 8:07am
Did you saved your settings into one of the profiles, Aquaero would load your settings of that :S
This post has been edited 3 times, last edit by "Dundys" (Apr 9th 2017, 8:13am)
Fieldrider
Sunday, April 9th 2017, 4:52pm
Oh jeah, thats the next point. Did you select a different Profile (2-4) in the Aquero Settings tab and saved your settings there?
I actually don't believe in it, but If you would have done so then I need to say: The Aquaero always starts with Profile 1 as default.
Dundys
Sunday, April 9th 2017, 8:02pm
Actually, when you set your preferences save them somewhere on your hard disk and than afterwords load that file and save as profile, than reboot and load that config. again, do it 2-3 times sometimes aquasuite and AQ get glitchy I had that issue 1-2 years ago but it works great ever since.
If that doesn't work, you definitely have issue with the unit and its time to RMA
This post has been edited 1 times, last edit by "Dundys" (Apr 9th 2017, 8:03pm)
Monday, April 10th 2017, 11:11am
Quoted
You have to wait a few secondes before you can disconnct the device.
