• 30.09.2026, 23:43
SverreMunthe
Problems with LT as a slave
Sunday, April 30th 2017, 4:28am
I've had this problem before, with both a 6 XT running a 5 LT as a slave and a 5 XT running a 5 LT as a slave.
I just bought an Aquaero 6 LT, changed the display from my XT and set up the old XT, now LT, as a slave (up to date on FW). For a while it worked well, but when I disconnected a fan (while the PC was running) I lost the slave. Checked cables (only Aquabus and 4 fans) and everything seems fine. The slave doesn't show up as a connected Aquabus unit on the XT. Rebooted twice, doesn't help. All units have different adresses. Aquastreams 10 and 11/18 (ultima), mps's 12 through 14, Farbwerk (forgotten the number, but both have different numbers). I did not set an adress on the slave, not sure if you can, and it's the only one, so doesn't matter.
Any suggestions? My experience so far is that if it works, don't touch anything, and if it doesn't, pray it will get back after the next reboot.
GTXJackBauer
Sunday, April 30th 2017, 4:40am
I would never recommend on connecting and disconnecting when the PC is on. I did that once on a fan cable on the MB and lets just say, I almost burned my hands and the fan cable melted.
It's possible, you might have fried your slave but hope that's not the case.
Pilo
Monday, May 1st 2017, 1:39am
Have you tried to reset the Aquaero units to factory setting?
SverreMunthe
Monday, May 1st 2017, 2:34am
It worked again, then stopped working. I'll do some more checking, but had it been this soecific unit, why has it happend several times earlier, with different units and on different computers?
SverreMunthe
Tuesday, May 2nd 2017, 11:31am
And, it's working again. Guess I just have to turn off the PC (remove power) and pray to some obscure god of Aquabus connections when ever it choose to shut down the connection. :(
Similar threads
