• 01.10.2026, 04:23
huanghetv
about aquabus cable
Monday, May 8th 2017, 1:30am
Good lucky everyone.
I buy Product (No.: 93111) ,It has 3 pin,but AQ6、D5 Aquabus port have 4pin connector.then I have two question:
1)Can I use this 3pin cable(aquabus / RPM signal cable) connect AQ 6--D5 by aquabus?
2)Can I use 4pin fan extension cable to connect AQ 6--D5 by aquabus?
ths.
Monday, May 8th 2017, 7:16am
JasonMorris
Monday, May 8th 2017, 5:03pm
I will preempt the next question if I may with "is it the same as a 4 pin fan extension cable"?
GTXJackBauer
Monday, May 8th 2017, 11:31pm
No because it's female to female. I will say, I'm not sure if the wires are crossed at all and if they're not, you could use PWM cables as extensions to the female to female aquabus cable but I'd rather wait for a confirmation from AC.
JasonMorris
Tuesday, May 9th 2017, 2:12pm
I realise its F/F but was wondering, as you have mentioned, if the wiring is the same.
Tuesday, May 9th 2017, 9:27pm
The specification for the cable linked by Sebastian includes the following:
Quoted
Specifications:
4 pin female to 4 pin female connector, connected 1:1
I believe 1:1 means straight through, so a 4-pin PWM cable should work fine.
huanghetv
Wednesday, May 10th 2017, 10:26am
I see. Thanks. :)
Jakusonfire
Wednesday, May 17th 2017, 1:20pm
Some MPS devices need the 5V power supplied by the 4th wire on the 4wire Aquabus cables but the USB D5 does not. It works just the same with the 3 wire Aquabus cable as it does with the 4 wire.
The Aquabus cables are the same as fan cables. Any fan extension can be used to extend and any female to female fan cable can be used for connections.
