You are not logged in.
Undesirable
This post has been edited 1 times, last edit by "Undesirable" (May 31st 2017, 10:05pm)
Undesirable
This post has been edited 4 times, last edit by "Undesirable" (May 31st 2017, 7:30pm)
Undesirable
I have the same setup and it works fine, only difference is i'm not using sata power. I have connected the MB to the IN on the hubby and then connected the aquaero to position one on the hubby and it all works fine. When I get home i'll attach a photo![]()
This post has been edited 6 times, last edit by "Bartdude" (Jun 7th 2017, 7:37am)
Undesirable
This post has been edited 1 times, last edit by "Undesirable" (Jun 9th 2017, 2:06am)
Undesirable
This post has been edited 2 times, last edit by "Undesirable" (Jun 9th 2017, 5:03pm)
Undesirable
Your video show the cable to the Hubby7 is connected correctly and the jumper is set correctly.
I am curious, for the direct connect test, which cable did you use between the aquaero and the motherboard USB port?
- the cable from your aquaero to the Hubby7?
- or the cable from the mobo to the hubby7?
This post has been edited 2 times, last edit by "Undesirable" (Jun 12th 2017, 12:58am)
Undesirable
You maybe correct, I have read several posts about problems with USB and the X370 chipset. Those screenies you took in your first post, they were while the Aquaero was connected through the Hubby7? Can you actually install the Aquaero with a direct connection to the MB, including see it In Aquasuite with a valid license? Just trying to eliminate possible problems.
For direct connection, I remove the USB cable that is plugged into port 1 of the Hubby 7 in the video (the cable used is the long one bundled with the Aquaero), remove the short cable attached from the Hubby 7 to motherboard, then plug the cable that was in port 1 of the Hubby 7 into the motherboard header.
I know the Hubby 7 + Aquaero setup should work, because it works in the same configuration with my Aquastream XT. I have also tried all the ports and switching the USB cables. I can also see that my Aquaero 6 Pro works when connected directly to the motherboard.
Undesirable
Well, that rules out the cable for the most part.
Your best bet now may be to contact support@aqua-computer.de.
