• 01.11.2026, 00:11
racecar
Aquabus D5 and 6XT regulation
Friday, July 28th 2017, 12:16am
I would like to advise how to regulate this pump. I plugged it into the highflow connector in the aqua6xt if I click to pump in aquasuite - nothing to change and the pump goes still at 3000rpm. Any info what am I doing wrong? I dont have pluged USB cable.
Thanks. :huh:
EDIT: Here is image: http://i.imgur.com/mPkZsWv.png if i slide slider anyhow still the same speed.
This post has been edited 4 times, last edit by "racecar" (Jul 28th 2017, 12:33am)
Jakusonfire
Monday, July 31st 2017, 4:53am
Becuase as the image shows you have the minimum speed set to 68% and the maximum to 100%
Setting the preset slider to 6% makes the pump run at 6% of the range from 68 to 100 which is 71. If you set min to 50% and max to 80 with the preset to 50% the pump will run at 50% of the range between 50 and 80 which would be 65%
If you set the min to 0 and max to 100 you will get the full range of control
racecar
Monday, July 31st 2017, 2:56pm
Of course, I understand, but rpm does not change when i slide with the sliders anyway.
http://i.imgur.com/1XVz3c1.png
Wednesday, August 2nd 2017, 11:10am
You have to setup the Bus Priority to aquabus in the system tab. To edit this you have to connect the pump via USB.
racecar
Wednesday, August 2nd 2017, 12:44pm
Many thanks.
It works well. ^^
