• 17.07.2026, 08:58
Elderdeekey
Aquasuite autostart in desktop mode?
Friday, September 8th 2017, 4:22pm
I'm using Aquasuite 2017-2 with Flow sensor high flow USB. Got 3 sensors to display data on my screen in desktop mode.
Is there the way to start Aquasuite in that mode when Windows 10 starts?
I do have all 3 options marked for Application startup (Minimize at startup, Minimize to system tray, Start aquasuite with Windows) and program autostarts OK, but bringing those 3 sensors charts on the desktop requires manual opening aquasuite, clicking on "desktop mode" icon and then minimizing program...
Sunday, September 10th 2017, 3:17pm
Do you have both the Lock symbol locked and the Desktop Mode toggled (orange arrow showing)?
Elderdeekey
Sunday, September 10th 2017, 8:56pm
Yeap, and that is how I got my 3 sensors on my Windows desktop.
So what I want is that 3 sensors data is loaded automatically when Windows starts. As of now it doesn't with setting as you suggested and which are my settings as well.
Elderdeekey has attached the following files:
Tuesday, September 12th 2017, 2:02am
OK, then click on the gear icon for the page you want to display at startup, and tick the "Load page automatically" box.
That should get you going.
Elderdeekey
Tuesday, September 12th 2017, 10:56am
I've answered initially "It doesn't help" as I've checked it from the very beginning (see attached screencap).
But then I decided to double check it...
The sequence was:
1. Closing Aquasuite while it is minimized to system tray AND is running in desktop mode.
2. Starting Aquasuite w/o Windows restart.
Well, magic happened - it started minimized and in desktop mode, meaning my 3 sensors are properly displayed on my desktop.
I've also reboot and, YES, it works as well.
I have no clue was/is it a bug in Aquasuite or "a feature" :P
Anyway, it works as I want and my appreciation to InfoSeeker :thumbsup:
Elderdeekey has attached the following file:
  • autostart.JPG (45.06 kB - 469 times downloaded - Last download: Yesterday, 11:05am)
This post has been edited 2 times, last edit by "Elderdeekey" (Sep 12th 2017, 11:05am)
Thursday, September 14th 2017, 4:48pm
The trick is when you set up the automatic page loading stuff, you have to close the aquasuite the normal way so it can save all these settings.
If you let the aquasuite just run with these new settings and then shutdown the PC, they will not be saved. This is the reason why you are back at where you started after the next system start.
Wednesday, September 20th 2017, 11:50pm
That I was not aware of... I thought aquasuite saved vales when you exited a field... very good to know, and will probably save me headaches in the future.
Andrew LB
Monday, September 25th 2017, 4:37am
Ahh! Finally it works! Thank you Shoggy! My only annoyance now is the desktop sensors shifting around on my right display when I change resolution for a game from 1920x1200 to 1920x1080 on the left display. The right display stays at 1920x1200 as it should, but the displayed information moves partially offscreen.
https://aquasuite.aquacomputer.de/cf549952-84b5-46f3-8830-49c5155c3f95.png
Tuesday, September 26th 2017, 1:45am
Does the desktop senso0r move down off the screen, on the second monitor?
