• 10.10.2026, 23:49
DirtyBear
Flow sensor high flow USB G1/4
Monday, October 23rd 2017, 5:52am
Hi Guys !
Could anyone tell me is there a software for this High Flow USB sensor
Coz this is what it shows at my Aquasuite
Thank You
DirtyBear has attached the following image:
Dundys
Monday, October 23rd 2017, 9:11pm
How do you have that connected. It should show as a mps1 under aquabus device and than under Sensors/ flow sensors/ however you name it.
Did you allocate bus address for the flow meter
This post has been edited 1 times, last edit by "Dundys" (Oct 23rd 2017, 9:13pm)
Tuesday, October 24th 2017, 3:14pm
There is everything OK. The High Flow sensor has no configuration menus in the main tab. You can see the current flow rate in the alarm configuration tab or as flow sensor X in the sensor tab if you use it together with an aquaero via aquabus.
The sensor should have also created an new overview page where you can see the flow rate. Easiest way to get it again: disconnect USB, remove the dead menu entry for the sensor and connect the sensor via USB again. It will set up the overview page automatically.
DirtyBear
Wednesday, October 25th 2017, 3:59am
Thx Sven ^^
